show esrp counters
show esrp {name} counters
Description
Displays ESRP counter information for ESRP or for a specified ESRP domain.
Syntax Description
name Specifies an ESRP domain name.
Default
Displays summary ESRP counter information.
Usage Guidelines
The show esrp counters command displays information about the number of:
  • Failed received protocol packets
  • Failed sent protocol packets
  • Dropped protocol packets belonging to unknown ESRP domains
  • Dropped protocol packets due to invalid Extreme Encapsulation Protocol (EEP) data
  • Dropped packets due to old sequence numbers
  • Dropped packets due to an invalid 802.1Q tag
  • Dropped packets because the packet length was truncated (packet length is less than expected)
  • Dropped packets due to failed checksum verification
The show esrp {name} counters command displays information about the number of times ESRP, ESRP-aware, and ESRP error packets were transmitted and received.
The following command displays ESRP counter information:
show esrp counters
The following is sample output from this command:
Current-time:                    Sun Nov 16 00:25:08 2003
esrpStatsRxHelloFailed           = 0
esrpStatsTxHelloFailed           = 0
esrpStatsUnknownDomain           = 0
esrpStatsUnsupportedEEPVersion   = 0
esrpStatsInvalidEEPLength        = 0
esrpStatsNotInTimeWindow         = 0
esrpStatsInvalid8021Qtag         = 0
esrpStatsInvalidSNAPType         = 0
esrpStatsUndersizePkt            = 0
esrpStatsInvalidChecksum         = 0
esrpStatsWrongDigest             = 0
The following command displays counter information for ESRP domain ed5:
show esrp ed5 counters
Domain:  ed5              Current-time:  Sun Nov 16 00:25:27 2003
Rx-Esrp-Pkts         = 628        Tx-Esrp-Pkts         = 630
Rx-Aware-Esrp-Pkts   = 112        Tx-Aware-Esrp-Pkts   = 34
Rx-Err-Pkts          = 0 Tx-Err-Pkts          = 0
This command was first available in ExtremeXOS 11.0.
Platform Availability
